Here is a list of a few Head casting #'s
Old 03-06-2010 | 02:23 PM
TexasGMC's Avatar
Registered User
Thumbs up Here is a list of a few Head casting #'s
853 97-00 aluminum 5.7
241 01-03 aluminum 5.7
243 LS6 aluminum 5.7
852 and 706 99 and up 4.8-5.3 truck heads
873 99-00 LQ4 6.0 iron heads
317 01 and up LQ4 6.0 aluminum heads
035 02 and up LQ9 6.0 aluminum heads
Even more info:
Casting Number 241
Head: 1997+ LS1 5.7 Litre Passenger Car
Material: Aluminimum
Part Number:
12559853 (1997-98)
12559853 (1999-00) (not sure why same PN)
12564241 (2001-03)
Combustion Chamber Volume: 66.67cc
Compression Ratio: 10.1:1
Intake Port Volume: 200cc
Exhaust Port Volume: 70cc
Intake Valve Diameter: 2.00 inches
Exhaust Valve Diameter: 1.55 inches
Casting Number 243
Head: 2001 LS6 5.7 Litre Passenger Car
Part Number:
12564243
Combustion Chamber Volume: 64.45cc
Compression Ratio: 10.5:1
Intake Port Volume: 210cc
Exhaust Port Volume: 75cc
Casting Number 706
Head: 1999+ LR4 4.8 Litre Truck
1999+ LM4 /LM7 5.3 Litre Truck
Part Number:
12559852
12561706
Combustion Chamber Volume: 61.15cc
Compression Ratio: 9.5:1
Intake Valve Diameter: 1.89 inches
Casting Number 373
Head: 1999-2000 LQ4 6.0 Litre Truck
Material: Cast Iron
Part Number:
12561873
Combustion Chamber Volume: 71.06cc
Casting Number 317
Head: 2001+ LQ4 6.0 Litre Truck
Part Number:
12572035
Compression Ratio: 10:1
Old 03-06-2010 | 02:25 PM
supercharged680's Avatar
good info there... thanks!
Old 03-06-2010 | 04:44 PM
ForcedTQ's Avatar
Lightbulb
You can add the info for the 799> equivalent of a 243 but more found on the H.O. 5.3's and GMT900 4.8/5.3's.
Old 03-07-2010 | 11:43 PM
00ChevyScott's Avatar
Wearin' da big hat
862**** not 852, and I've never seen an LQ9 with 035 heads...
Where are you getting your information?
Old 03-08-2010 | 02:19 AM
Low_LSX's Avatar
Formerly Low_LQ4 - 6/6/10
Repost. If you go to the top of this section of the forum you will find the sticky to all this info and more.
https://www.performancetrucks.net/fo...d.php?t=434396
Old 03-08-2010 | 02:21 AM
Low_LSX's Avatar
Old 03-09-2010 | 11:03 PM
budhayes3's Avatar
PT's Slowest Truck
Every LQ9 that I've seen has had 317 heads
Old 03-09-2010 | 11:12 PM
_zebra's Avatar
makes children cry
correct me if i'm wrong, but don't the 317 heads have a lower CR than that?
Old 03-09-2010 | 11:48 PM
1Bear's Avatar
The LQ9 as equipped with the 317's is rated at 10.0, while the LQ4 was rated at 9.4.
I don't know of anyone who has ever seen a LQ9 with factory installed 035's, but they were sold a a service replacement and is what Patriot used to use to base their LS6 heads off of after filling the combustion chamber, as well as their 6.0 heads.
Old 03-10-2010 | 01:13 AM
TexasGMC's Avatar
Registered User
My pop has a michine shop.
Quick Reply: Here is a list of a few Head casting #'s
