here we go again/Transgo
m in the middle of the transgo sonnax vette servo install and need some help
the video and instructions for the transgo have got me confused
the video shows a checkball going back in the spring of the small hole
at the forward accum not where the pinless piston is where you have to take the roll pin out
if that made any sense whatsoever
well when I took the roll pin out it shot out and i looked all over for the check ball and couldnt find it so I put it back without 1
will that be ok?
what does sonnax mean by
lightly stake the pin bore after pressing in *****?
for the release servo valve
when sonnax says spacer plate is that the seperator plate?
how large to drill orifice A and B when using a vette servo?
how large to drill holes for seperator plate
I see nine holes to drill 1-2 and 2-3 is labeled but not 3-4
Hitman said long ago 1-2 .070 2-3 .093 3-4 .082
where is 3-4 and what about all the other holes
would it be safe with .082 on all the rest?
that was chapter 1 ill probably write chapter 2 tomorrow
Thanks yall
will that be ok?
Thanks yall
will that be ok?
I'm going to do my install this weekend. I will be installing a Corvette servo, cooler, and a Transgo. I want it to shift just a little more firm than stock at part throttle. I wanna hear 'em bark at WOT. Any idea on how to do that? I have HP Tuners if I need to do something in the PCM to accomplish this.
thats good to know I didnt lose one of my *****
when I put the 2 ***** in behind the pinless acc valve
I set the vb on end and drove them in lightly with a punch
that was about the same size as the ***** ...worked great
I want it to feel normal until I get on it
I saw a Z the other day that barked 2 at any speed
thats just not for me
I want short definite shifts
i think they might have given me to big of check *****! the only way to get mine in there would be to drill the valve body out, or maybe beat the **** out of them untill they go in!!!
with the super servo in i can bark the tires now its sorta cool, but im sure it will get old quick. it shift hard just crusing.
redvho im not sure how your going to do that. i think you are going to have to pick one. there might be a way to get it to work maybe its drilling out a couple of the 9 holes and leaving some stock. but i have no idea
Originally Posted by TheLadiesMan
i think they might have given me to big of check *****! .
.... or a paper clip
Id be scared to pound those in mine went in pretty easy
with a little encouragement
Originally Posted by gamedawgx53
dont feel bad ,transgo didnt send me the purple spring
i dont think i will be pounding them in i already go the truck back together. i guess it will just have to wait
