Heres one for you tech heads.....
#21
single digit dreamer
i still haven't heard how you confirmed the injectors are fireing. you should do that before you tear the motor out.
one way that will tell you something is let the fuel pump prime up to 5x. psi. presure should hold with the key off. then pull the fuel pump fuse and crank it over. the presure should drop if the injectors are opening. if the presure stays the same then the injectors are not opening.
are the plugs damp at all or dry? do they smell like fuel?
#23
LOL no extra pushrods. We confirmed fuel 2 ways: one we pulled the plugs and got fuel pushed out of the plug hole on the compression stroke, the other way we just pulled the rails with the plugs attached and let them fire. LOL lets just say they have a very nice atomized spray. Eau de gasoline anybody
Went over all the sensors to make sure everything was tightly plugged in - they are. That was the first thing we did. Then we checked all the grounds - they are still all good.
My brother actually said bent pushrods when I first called him. I just refused to believe him. Maybe tomorrow I'll have some new news.
#26
You guys ready for this? I have egg on my face...lol. The plugs were too cold. Put in the old stock ones and she fired right up. Now I just need to go get some tr6's and should be all set.
