Hey Blown
#31
Sport and others that have played with a lot of cams and cam science.This question may sound different than my original question. We all know blowns set up.I am wondering what could be better about his cam,while staying in the same duration and lift range. Now maybe you cant answer that without more info.This is about as simple as I can break it down.Now for my application I described,I would want a cam prescription close to the GT2-3,if it could be better I am all ears. I feel 6K RPM is the magic number,not looking for lope,easy Idle tune,maximize the radix.The use of LS6 springs and quiet operation,I am thinking in the area of 210/570/115 0r 116,I know that doesnt tell all of the story event timing or lobe design but I dont think I am far off.
Open for all to respond
#32
what a rush!
sorry sportside, don't feel like getting all that deep into cam specs and valve events today, maybe after the holidays.
#33
i spent more than my share of time learning camshaft mathematic's and on the same side have spent time on the testing and research side. sometimes you can overcalculate going fast...
#35
TOTM: January 2007
I did some reserach on cams, and I had various recomendations. Actually when I called Lingenfelter, they told me the gt7 was the cam to chose with the radix, which is 208/230.
I was then puzzled, however i seen the results blown had 44rwhp, and remember charris having a good experience with the gt2-3 in his h2. Here is a reply to a PM I had sent him. I consider him to be very reputable. He also went from a larger cam to a smaller cam with no change in performance.
Here is the PM;
Re: Cam Question
Quote:
Originally Posted by j's01silverado
I know you have expereince with cam swaps and the radix. I have been researching to determine which cam to go with. Can you please offer any insight or ideas about these 2 cams or others that would provide good results. Have an 01 ecsb 5.3. Current stall at 2000 rpm and dont plan on going any higher.
LPE GT2-3, 207/220 .581/.587 118.5cl.
OR
LPE GT7 cam, 208/230 .554/.556 121 cl
Lingenfelter recommends there gt7, but I see that you and brain both went with the gt2-3 and had favorable results. What are your thoughts?
Thank you. Really appreciate your help!
Jason
Jason,
You just can't go wrong with the GT2/3. Its a proven combo that doesn't bleed off excesive boost. I ran the 215/232 CheaTR cam and it ran the same times as the exact same combo with the GT2/3. The smaller GT 2/3 gave the best driveability and makes it my only choice.
Let us know what you go with and how it goes. The right cam can really wake that combo up.
Cory
Here is the PM;
Re: Cam Question
OR
Jason
Jason,
Cory
lycominghunter
26
09-25-2015 07:50 AM
