Hi-temp engine coating...(rattlecan)
Old 08-26-2009 | 11:42 PM
sc_customs's Avatar
Default Hi-temp engine coating...(rattlecan)
Worth it? I bought a set of pacesetters non-coated and was debating.
Old 08-27-2009 | 12:06 AM
L7 Sierra's Avatar
I will last a bit but it always burns off again. Its not thick enough and most importantly annoying.
You have to sand them completely.
Clean them completely
spray them with 4 coats
then in-stall them and start the motor to bake on the coating. In less then 3 hours after you paint.
I recomend a test fit first to see where you can go wrong if at all.
Old 08-27-2009 | 12:07 AM
L7 Sierra's Avatar
They work great on motors, trannys, accesories, but not headers
Old 08-27-2009 | 12:14 AM
RandomHero's Avatar
I'm tempted to try some of the coatings POR-15 sell. They have some that are rated from 1200* up. I haven't checked to see how hot turbo parts get, but that seems like a pretty big number.
Old 08-27-2009 | 02:13 AM
Spoolin's Avatar
GFYS and STFU
I just bought a can of this today and it claims to be used on headers and withstand up to 2000 degrees...
I'm not planning on coating my headers but if I take them off again I might!
Old 08-27-2009 | 02:14 AM
Spoolin's Avatar
GFYS and STFU
Depending on your tune it can get to 1800-2000 degrees if your really rich. None of which is good.
Old 08-27-2009 | 02:55 AM
sc_customs's Avatar
that's what they have at autozone (checkers i think elsewhere?) I know the dupont stuff didn't hold up on my buddies truck but i figured this might be different
Old 08-27-2009 | 08:25 AM
Coban's Avatar
To get the paint to stick right surface prep will be most important.
With high-temp coatings, the thinner the better. Even then, it won't last forever.
superchomper2003
08-26-2015 10:39 AM
nrmskate
08-11-2015 03:44 PM
DrX
08-11-2015 08:25 AM
GMCtrk
38
08-09-2015 09:50 PM
85SS/85GN
07-22-2015 01:48 PM
Quick Reply: Hi-temp engine coating...(rattlecan)
