High Idle ???
sticky throttle plate ,i just had issues with similar ,and i did have a bad tune also but that only started at 2k rpm then slowly went down.i also had the same issue with a big vaccuum off ,just my piece of mind
check the vaccuum lines..could be in the throttle plate too...what i did to mine to get it to idle great is unplug the IAC motor and move the set screw to what the desired idle rpm is in the tune..that way the IAC motor doesnt havent try and keep up if the the throttle plate isnt opened far enough or too much
I got a new IAC. Put it on... and back to idling high. The only thing I can do to fix this is to manually move the plunger myself. So I have it set at 750-800ish.
Another thing I noticed when i start the truck (warm or cold) i have to give it a little gas to keep it running. It will bog down the idle up a little, bog down idle up a little. Then after a few sec. its ok I can drive, idle fine. Any ideas?
