high impedence vs low impedence injectors
the only diffrence is you can go bigger for more fuel....also might use this with em...
http://www.acceleronics.com/versafueler.htm
im gonna try 75's and the versa fueler on the 408....
I AM A MOTHERF*CKER
Going bigger in an injector means that the components that open and close get bigger and weight more. So the higher you go with high impedance means the more sluggish they become opening and closing.
High-z injectors require little current to open, while low-z injectors require a lot more (around 4x as much). Peak and hold drivers apply this large current to snap the injector open, and then ramp the current down to just enough to hold the injector open (about the same as high-z current). What this means practically is that you can run a very large injector and get the same opening and closing performance as a much smaller injector. This means better idle, better non-wot performance, easier tuning, etc.
The versafueler is awesome Bud. VF + 75s with stock tuning idled better than my moto 60s and many hours of tuning.
Moderately Differentiated
How do I change this text
Originally Posted by dewmanshu
that's bad ***! 400 bones at first sounds high, but man...looks great and easy.
TX Tahoe Z71
09-01-2015 09:11 PM
