High pitched noise in engine bay, help
Old 03-31-2010, 08:36 PM
I have a gauge for that
Atomic's Avatar
Default High pitched noise in engine bay, help
This started happening a few days ago. Its loud enough where I can hear it over the engine running sitting in the truck with my windows down and hood closed. It only does it when the engine is running and does not appear to change with RPM. I double checked the TB and it is fine. I havent changed anything in 2 weeks and then this starts one day...
http://www.youtube.com/watch?v=SPUZ5Osyawg
Any suggestions?
Old 03-31-2010, 09:09 PM
f4tal's Avatar
at first just by reading the title i was going to say thats what the blower does...
but reading the thread and watching the vid... sounds like a vaccum leak or somethin, def not supposed to be there. Is your truck a SD tune?
Old 03-31-2010, 09:18 PM
Atomic's Avatar
Yep, 2bar SD.
I couldnt see anything wrong when I put the scanner on it (hptuners), and there is no change in drive-ability.
I thought vacuum leak too, but from where....
Old 03-31-2010, 09:22 PM
Where's the Beef?
viciousknid's Avatar
There are a few threads of a problem like this that turned out to be a vacuum leak. As i recall it was an easy fix.
If I run across something I'll post up.
Old 03-31-2010, 09:27 PM
james8997's Avatar
carb cleaner is your friend when looking for vacuum leaks
Old 03-31-2010, 09:31 PM
Atomic's Avatar
care to elaborate?
Old 03-31-2010, 09:38 PM
james8997's Avatar
im not completly sure if it works on newer LS engines but i dont see why it wouldnt.
spray carb cleaner around any vacuum hose, or anywhere vacuum could leak, if/when you hear the engine increase in RPMs, you found it. works wonders when i was chasing a vacuum leak a few years ago
Old 03-31-2010, 09:41 PM
dlt76028's Avatar
Man thats loud. I would think vacuum leak, what do your trims look like? What about the boost a pump? I heard they sound like a jet.
Old 03-31-2010, 09:46 PM
Atomic's Avatar
i have an in-tank walbro 255
the leak is very loud, loud enough to hear over the truck sitting at a stop sign with the hood closed and windows down.
trims are within 3% at idle
turning on the AC doesnt change anything for what its worth
Old 03-31-2010, 09:50 PM
dlt76028's Avatar
Alternator... Hell I don't know, sounds electrical.
Quick Reply: High pitched noise in engine bay, help
