hmmmmmm?
Old 12-07-2005, 10:55 PM
  #21
Kano's Avatar
Originally Posted by brian4.8
There is no way that a bad coil will show up as lean.... If anything it would read rich b/c it was misfiring and not burning fuel. It sounds like you gentlemen have dirty injectors!!!
typo fixed
thanks bro
Old 12-08-2005, 07:06 AM
  #22
12 Second Club
ThunderZ28's Avatar
problem fixed
motor runs much better..
thanks for the info...
Nathan...
the tips on 2 sets of NGK's( where the boots connect as 1slowz71 stated above) that I have bought would vibrate loose, and it would start running rough, so to try and fix the problem I put some lock tite on the threads that the tips screw onto..
well apparently I put tomuch lock tite and it was impeeding the spark.. changed the resistance, and so it would spark just not spark enough causing it to simulate a dead cylinder..
well I had 3 of these that had lock tite on them, so you can imagine what 3 cylinders running on half spark would feel like very noticeable...
thanks again guys for the input.
Daniel
Old 12-08-2005, 08:34 AM
  #23
BLACKND's Avatar
I had never thought about putting loc-tite on there. I was having that same issue with my 04 and just kept going back in every few days and tightening them up. That got old real quick.
Old 12-08-2005, 09:52 AM
  #24
12 Second Club
ThunderZ28's Avatar
yes it did
Old 12-08-2005, 09:57 AM
  #25
SSlow 4.8's Avatar
this happened to me the other nite...i was freaking out. Lock-tite is a good idea tho.
Old 12-08-2005, 10:39 AM
  #26
TXsilverado's Avatar
anyone got a picture of what the hell yall are talking about? is this something that happens with only the ngk plugs or what?
Old 12-08-2005, 11:37 AM
  #27
12 Second Club
ThunderZ28's Avatar
I can get some tonight when I get home form work, as to what exactly was going on...
Old 12-08-2005, 11:45 AM
  #28
12 Second Club
ThunderZ28's Avatar
here maybe this will help..
i found this illistration, so I noted what we are talking about
Old 12-08-2005, 11:48 AM
  #29
cool thanks. is that only a problem with the ngk's or is it for delco too? im just plannin new delco plugs when/if i put my headers on.
Old 12-08-2005, 12:09 PM
  #30
BLACKND's Avatar
I never had it before except on the NGK's
Quick Reply: hmmmmmm?
