HOLY SHAT! Broke A Valve Cover Bolt Into Heads PLEASE HELP!
I can't believe it. I wasn't even putting much stress on the bolts at all, I was going to torque to specs, and didn't even get there and the damn bolt just snapped! It's broke off flush in the head. That's just the kinda luck I have. All of this weak aluminum **** is pissin me off. If i drill it out, then I'll proally screw the threads up inside the head. I'm stuck until you guys can help me out!
I just snapped a headbolt off in the shortblock so its not as bad as I had it this weekend (new shortblock). Have you ever extracted a bolt? If not, take the truck to a reputeable machine shop and they can more than likely get it out! Calm down and worry not, its not as bad as you think.
YEA! I can't believe it actually went that smooth. I drilled it out, wedged a ease in there and unscrewed the bolt. I bet I was .00005 mm from the threads on the head with the drill, it scared the crap outta me! Anyways, on with the build of the beast! THANKS GUYS
I broke a head bolt off in the block about 6" deep while doing the final round of tightning. Took me about 2 hours to rig up a long enough ease out. Later as I broke a second one it took about 15 minutes to get it out.
How in the hell did you get it out? I talked to a machine shop and they said they couldnt get it out. Another member has my block now so im sure he would love to hear this.
Noah Burns
09-07-2015 05:50 PM
low2001gmc
07-21-2015 02:09 PM
