hot chick sway bars
hot chick sway bars
i need to know if hotchkis sway bars (stock height) would fit on this suspension:
Aftermarket Shocks
2'' rear drop shackles
Cal tracs
anyone see any problems with this?
Aftermarket Shocks
Cal tracs
I imagine they would.
The Silverado SS's are the same as Z71's, but without the 2" lift blocks under the springs. The standard 'stock height' hotchkis bars work on the SS's.
The Cal Tracks may be in the way. I just recently put Cal Track bars on a 92' Truck. We had the Hotchkis pan hard bar on it would not bolt back on. The Cal Track are sure cool though!!!
From what I have found is The only differance in sway bar applications is the length of the end links. A 4wd sway bar is the same for a 2wd. The end links are going to be differant lengths.
Cal trac bars will not interfere with the Hotchkis sway bar.
Hotchkis hasn't developed a pan hard bar for the 99 nbs trucks because I don't believe they need one like the old body styles did. the old style having the Thicker frame, differant shock layout etc..
I'm with creedarado.. they shouldn't interfere at all. They didn't on mine.
As for the sway bars .. new end links will fix any problems that might be and they should be fairly cheap.
are there any more pics of that link setup
carid
10-01-2015 09:22 AM
Wrecker 426
09-30-2015 09:39 PM
