How to add fuel pressure gauge to stock port?
I have a 1.5" Autometer gauge that I am tired of looking at...I can't sell it so I may as well stick it under the hood.
It looks like the factory schrader valve is a male end and the gauge is the same.
Any ideas how to hook them together?
Thanks!
Thanks!
Originally Posted by black_yukon
Check this thread for more info
https://ls1tech.com/forums/showthread.php?t=113195
Thanks and if all goes well more crap that doesn't make me faster under the hood.
Adkoonerstrator
The schrader valve just screws out and can be removed with a simple valve stem core remover.
The port on the fuel rail is -4AN so I don't think HD has that type of stuff. Any hydraulic shop will have the fittings you need, alot cheaper than that fancy anodized EARLS stuff too.
Adkoonerstrator
A -4AN fitting hose will have an inner diameter close to 1/4" but, the threads are not the same as NPT 1/4".
The guage you have should be male 1/8" NPT. What you need is a fitting/s that adapt male -4AN to male 1/8" NPT. Look at the attached pic. The blue fitting adapts from male -4AN to 1/8" NPT. Then you would use an 1/8" coupler to hook your guage up. Those are just some fittings I have laying around but, that gives you an idea.
More than likely you'll need two fittings to do what you want. If you go to a hydraulic store just tell them what you want to adapt to what and they'll help you get the right fittings.
BTW, AN fittings = no teflon tape NPT fittings = teflon tape.
Banned
hitman....go to speedtek in hurst and they will have everything you need for it. i had to make the same conversion from 1/4 to the -4an a while back for a fuel pressure gauge/nitrous system setup. they have it there
GMCtrk
07-17-2015 06:39 PM
Mossyoakglock
07-17-2015 08:30 AM
