how big can bore iron 6.0
Old 11-03-2008 | 05:33 PM
gmc03's Avatar
Default how big can bore iron 6.0
i have read that you can onlt bore a iron 6.0 .010 does anyone know how true that is. i have an 01 6.0 cast #12552216 wanting to make stroker please help thanks
Old 11-03-2008 | 08:31 PM
454SuperSport's Avatar
some have gone as far as .060. have your machinist sonic test the cylinders cause no 2 blocks are exactly the same.
Old 11-03-2008 | 08:34 PM
dirt track racer 81's Avatar
mine is bored .030. what do you have plans on doing? what size crank?
Old 11-03-2008 | 08:59 PM
gmc03's Avatar
wanting to build a super charged 383 but i found the info i posted on engine builder.com and i wanted to be sure before i bought the block
Old 11-03-2008 | 09:03 PM
Derek @ EDO's Avatar
FormerVendor
.030 is the max i would go.
You can go a tad more but i would save that for cushion area incase you ever have to re-bore/hone.
Old 11-03-2008 | 09:11 PM
stock48's Avatar
9 Second Truck Club
The 6.0L block I just sonic tested is over .300'' thick on the thrust, and .200'' on the rest of the cyl. I would probably go +.100'' for Na, but .030~.040'' for FI. Remember your only removing .050'' of materal on a +.100'' overbore.
gmc03's Avatar
does any one know were to find a good priced 383 stroker kit for this 6.0 if all the cylinder wall turn out to be in good shape
Old 11-03-2008 | 09:20 PM
cant get a 383 fkit for a 6.0, you can for a 5.7 ls1 block. like i said in my pm you can put a 4 in stroke in a 30 over 6.0 block and have a 408.. theres alot of 408s out there
Old 11-03-2008 | 09:26 PM
gmc03's Avatar
do you have any suggestions on a crankshaft
Old 11-04-2008 | 01:56 AM
silver-mod-o's Avatar
Hunt&Fisherator
I'm boring my 6L .060... But make sure you have enough cylinder wall to do it.
Quick Reply: how big can bore iron 6.0
