How to build an exhaust resonator tube to eliminate drone
Old 10-22-2013 | 03:46 AM
  #31
Choda's Avatar
Good question^^^
Old 10-22-2013 | 11:38 AM
  #32
Ferocity02's Avatar
Keep in mind the speed of sound will be higher inside the exhaust. 343 m/s is for sea level standard day conditions. The exhaust gases are much hotter and a mixture of air/fuel is present. The resonator tube is not passing exhaust however, so the temperature of the air inside it will not be as hot as the exhaust flow. I would use a value more around 400 m/s.
Old 10-22-2013 | 12:06 PM
  #33
smokeshow's Avatar
Mod with training wheels
That is why I made sure to note the temperature dependence in the first post. And yes, it works for any frequency that you wish to attenuate.
Old 10-31-2013 | 08:10 PM
  #34
lochrtj's Avatar
Registered User
Does the resonator have to be after the muffler? I would think before the muffler would have the same affect of canceling out the wave.
Old 05-18-2014 | 08:45 AM
  #35
Boost-freak's Avatar
i did mine before 3 days ago , now i have no drone at any speed
thanks op
Old 07-27-2014 | 08:50 AM
  #36
three8threestker's Avatar
Registered User
now i'm just wondering...some people say you go 180 and point the resonator towards the engine.what is the difference?? and yes does it make a difference to do it before or after the muffler?
Last edited by three8threestker; 07-27-2014 at 08:56 AM. Reason: forget a question
Old 07-28-2014 | 11:53 AM
  #37
kbracing96's Avatar
It makes no difference where you point it, I just put them, shape them where they will fit. I've always put them after the muffler.
Old 07-30-2014 | 08:40 PM
  #38
Registered User
thanks for the info!
Old 11-06-2014 | 12:13 PM
  #39
Eckoes's Avatar
Registered User
I've noticed that the drone occurs at different rpms depending on my trucks temperature. For instance when I first start it up and drive it, I hear the drone right at 1500 rpm. By the time I get home it's droning closer to 1800-2000 rpm.
My question for those of you that have built these tubes is how much of an rpm range is covered by one particular length? If I target the 1500 rpm drone my tube length is something like 32", if I target the droning at 2000 rpm it is 26"...How crucial is the exact length? Thanks for any input!
Old 11-06-2014 | 04:50 PM
  #40
kbracing96's Avatar
That's because sound travels at different speed at different temperature. I think 32 is enough either side of the "drone zone" to get most of it out.
Quick Reply: How to build an exhaust resonator tube to eliminate drone
