How can I disable the daytime running lights ?
"All Motor 9 Second club member"
Hey guys, how can the daytime running lights be disabled on a 2002 Silverado LS? Anyone got a link to a tech article or procedure for this? TIA.
James
James
Re: How can I disable the daytime running lights ?
On my 2000, you can hit the dome override button 4 times, then it will chime and the auto headlight and daytime running lights will be disabled. Then the headlight switch will work like a regular on/off switch. It will reset every time you turn off the ignition. There is a company called R&D that makes and overide relay for this, but it's like $85 <img src="gr_eek2.gif" border="0"> .
GTO Forum Director
[quote]Originally posted by Fast4.8:
<strong>On my 2000, you can hit the dome override button 4 times, then it will chime and the auto headlight and daytime running lights will be disabled. Then the headlight switch will work like a regular on/off switch. It will reset every time you turn off the ignition. There is a company called R&D that makes and overide relay for this, but it's like $85 <img src="gr_eek2.gif" border="0"> .</strong><hr></blockquote>
That's for the "Twilight Sentinel" feature. The auto headlights. Mine only takes twice to shut them off.
To disable the DRL's, simply pull the fuse on GM trucks.
Mossyoakglock
07-17-2015 08:30 AM
GreyChevy
07-07-2015 08:57 PM
