how to change valve seals?
Old 09-15-2011, 04:40 PM
Notorious BIG
Holty's Avatar
Default how to change valve seals?
When i installed my comp 918's i didn't need to change the valve seals. I just got the PRC spring kit that comes with them so i might as well change them out while i'm in there. Just not sure what the process is?
Old 09-15-2011, 04:46 PM
Steve-O-08's Avatar
Once the valve covers are off, pull the rockers, then the springs, and you can pull the seals out with pliers. To put the new seals on match the correct color seal with the valve and you can seat them with a socket and a few light taps with a hammer. Pretty simple.
Old 09-15-2011, 04:47 PM
kbracing96's Avatar
Pop the only ones off and pop the new ones on. Really easy
Old 09-15-2011, 04:49 PM
Notorious BIG
Holty's Avatar
perfect, thats what i had hoped was the answer. thank you.
Old 09-15-2011, 05:33 PM
I have a gauge for that
Atomic's Avatar
you can use a socket or the tool meant for the job, its only $7 off ebay, its a kent moore tool
Old 09-15-2011, 05:35 PM
MASS seller approved
mitchellmade's Avatar
most new seals come with a sleeve that slides over the tip of valve and covers groove which the locks lock into so you do not damage the seal , if the seal tears a little it could smoke
Old 09-15-2011, 07:49 PM
11 sec. Truck Mod
TIM Z's Avatar
Dont forget to put air in the cylinder or some type of clamp to hold the valve if your doing this in the truck.
Old 09-15-2011, 09:10 PM
PT's Slowest Truck
budhayes3's Avatar
Yeah, it's just like doing springs with 2 more steps...your new PRC's may require the new valve seals actually, whereas the 918's are the same beehive design as the stockers and the stock seals will work. Point being, I bet that you need install the new seals no matter what
Goat's ss
01-03-2016 06:28 PM
Noah Burns
09-07-2015 05:50 PM
DrX
08-19-2015 04:45 PM
BigEd_72455
08-08-2015 04:49 PM
rojeho
07-12-2015 06:10 PM
Quick Reply: how to change valve seals?
