How do i get the Fan Assembly off??
Hey guys thanks for the help,
So im changing my water pump and im having trouble getting the clutch fan off, there is a big nut attaching the clutch to the pulley and when i change turn that nut both the pully and clutch move, when i hold the clutch and turn that nut just the pully moves rotating the belt. Any help on where to go from here is greatly appreciated. Thanks
There's a special tool that uses steel dowels that slide into the pulley in 4 locations.
I used a pipe wrench on the pulley with a wooden shim to keep the wrench from biting into the pulley, my uncle had a wrench specifically for clutch fan nuts that you could attach a 1/2" drive ratchet to use as a break-over bar.
EDIT: Didn't read the whole thing and read that you already had it off.
Just wanna say thank you, this was my first major job and its a good little pick me up, only major bump i hit was that big nut and not having a big enough wrench. Water Pump Complete!!!
blown02408
10-01-2015 01:06 AM
Wrecker 426
09-30-2015 09:39 PM
