how do you descreen your maf???
Old 09-12-2004, 01:22 PM
Thanks for the help guys. The screen will stay in.
Old 09-12-2004, 05:02 PM
4.8redchev's Avatar
Originally Posted by 02denali
the screen is not an airdam. it straightens out the air to allow the pcm to calibrate the airflow properly. at first it will feel great. then the pcm will learn it and it will go away. the chevy engineers did find one hp on the dyno--that was above 6000 rpm's. you need the pcm to read the air properly so that it can make proper adjustments. the turbulents that move past it will cause it to go either lean or rich bepending on what kind of day it is having. leave the screen in there.
damn this sucks....i took mine out and i can feel a difference but as you just said it will go away....is this going to cause a problem with my pcm and motor? and if it is how can i get my screen back in there? can you just buy a screen and put it in there? or am i going to have to buy a new MAF?
Old 09-13-2004, 11:22 AM
STOCK_SUCKS's Avatar
Im With 4.8redchev You Cant Get One From Gm But I Dont Know About Anywhere Else
Old 09-13-2004, 03:33 PM
Snafudilligad's Avatar
Originally Posted by Gordy M
I had the opportunity to talk to the chief LS1 engine management development engineer when the 2002 LS6 was introduced. He mention they took out the screen and found almost 1 HP on an engine dyno. over the 2001 Z06. Also, they had to make a PCM change to compensate for the lack of a screen. So if you make the change, update your PCM to compensate.
1 friggin pony. I wouldnt even take the 2 seconds to spit on an AC belt if someone told me that doing it prior to a race would add 1 friggin horse. Hell, just run synthetic oil and you'll pick up more than that.
Old 09-13-2004, 05:10 PM
Formerly one92rs
one03sierra's Avatar
Talking
nelson can tune for it. but i think in the end it is best to have it in there.
Old 09-13-2004, 05:20 PM
shandy294's Avatar
I heard about removing it from a radio show/mechanic/shop owner. He's a big-time Chevy lover and seems to have a lot of knowledge,in general,about car problems. Doesn't mean he can't be wrong about the screen,though. I didn't notice any difference in performance and I did it some time after I put on the FIPK.
Old 09-13-2004, 09:27 PM
Tribe Shaman
PappyDan's Avatar
it has been out for 6 months and i have had no problems with it being out that all of you describe on here, not running lean, not running rough, not shifting weired, i took it out when i installed the headders and dueled out the truck, i don't know what you all are experenceing with your trucks, but it is not happening with me on my truck.
it is a 2000 sportside with a 4.8 at 106000 miles
Old 09-13-2004, 11:28 PM
Nick99Chevy's Avatar
I did it on my '99, no noticeable gain, except for the gain in pinging when I ran 87 octane in it. No way in hell I'll do it on the '04.
Old 09-15-2004, 08:15 AM
superchargedchevy02's Avatar
Originally Posted by PappyDan
reach in with needel nose plyers and start pulling it out, it is just set in there,
as far as a gain 35% more air flow at WOT with less resistance, the screen acts like an air dam, why run a k&n filter to improve air flow if your just going to keep the screen to hold it back.
I'm just wondering were you came up with these numbers 35% seems like a good number to not be able to feel anything. I did it, got NO gain and would be willing to trade mine to any one who wants to do this for a stock one. Needs to be an 02 5.3.
lucas287
31
01-12-2021 06:18 AM
legerwn
56
11-15-2015 10:21 PM
JordanH
10-03-2015 03:59 PM
02AWDAWSDenali
10-01-2015 05:08 PM
ZxHybrid
09-18-2015 04:44 PM
Quick Reply: how do you descreen your maf???
