How do you guys dent headers? What's your preferred method?
Old 08-23-2009, 09:16 PM
hirdlej's Avatar
Default How do you guys dent headers? What's your preferred method?
I am changing some things around on my '70 chevy pickup and it has mild tube steel headers on it. I need to dent in one of the primaries about 1/4" to get my new clutch assembly to bolt in. I took a ballpeen hammer to it tonight (yes it's in tight quarters) and was unsuccessful in even putting a ding in it. WHen you guys need to dent your headers in, what do you do? Use heat? Get the area cherry hot, then hit it? Can a guy use an air chisel with a blunt attachment of some sort? Please give me any ideas you may have. TIA!
Old 08-23-2009, 09:18 PM
Baltimore Whore
Mangled03gmc's Avatar
What I would do is if it was in place while trying to so it, is get a tourch, heat it till it gets good and red in and around the area you want the dent in... Heat does wonders and it will look more uniform then a typical cold dent...
Old 08-23-2009, 09:22 PM
hirdlej's Avatar
So getting it cherry red with a torch will soften it enough that I can dent it in with only about 3 inches to swing a hammer? Does it matter if the headers are ceramic coated? By the way, this is in an area that no on would ever see, I don't give a **** what it looks like
Old 08-23-2009, 09:23 PM
Resident Retard
BlackGMC's Avatar
The way i have done it in the past is: get a round pipe, preferrably pretty thick and about 1.5 -2in diameter. Then put the pipe longways, where you want the dent then smack the pipe with a hammer, honestly I hit it pretty hard, remember this is steel your hitting... If coated, wrap the pipe with a towel...
Resident Retard
BlackGMC's Avatar
More than likely getting it cherry hot will burn off the coating, at least IMO...
Old 08-23-2009, 09:27 PM
phasemaster1's Avatar
Wow John wouldnt expect you to use a torch. Im sure if you had to do it a long burnout would get those headers cherry red then take the hammer to it...
Old 08-23-2009, 09:28 PM
hirdlej's Avatar
Yeah, unfortunatly I can't hit the header primary very hard as I don't have a lot of room to swing. Maybe I should bite the bullet and remove the header entirely from the drivers side. It's #7 primary and there's only about 5 inches between where I want to hit and the firewall. Quite frankly I don't care what the header looks like so using heat (if it works) would be a realistic option. I don't have a torch here at home, would a bernz-o-matic torch in a can (blue can) be just fine for getting the primary hot enough?
Old 08-23-2009, 09:29 PM
Dont think the blue can the yellow for sure.
Old 08-23-2009, 09:33 PM
black06's Avatar
MAPP gas (yellow) will do it ....I use that to straighten out my screwdrivers
Old 08-23-2009, 09:36 PM
hirdlej's Avatar
So this bad boy? Propylene Fuel cylinder?
Quick Reply: How do you guys dent headers? What's your preferred method?
