how do you line the flywheel holes up?
Restricted User
i just swapped converters and i cant get the converter to spin around so i can line the holes up with flywheel holes. is there a secret to this or should i have tried to line them up before i bolted the bellhousing to the block? help1
Well it depends on the converter...is the shaft of the verter (the end that goes INTO the crank) painted!?!? If its painted then it makes the fit VERY tight and almost impossible to spin by hand. Push the vert back into the tranny so its away from the flexplate and crank, use sand paper to get the paint off the shaft, then slide it back forward again and it should spin freely
