How to dyno tune an SS?
Old 01-05-2004 | 01:35 PM
  #21
boeman's Avatar
Pontiac Story... debunked (at least partially)
Old 01-05-2004 | 03:10 PM
  #22
Originally Posted by BigTex
You could fairly easily remove the transfer case and move to a 2wd tail housing and driveshaft. You are going to have many more problems swapping out the front end and removing the front differential. I guess you could leave hte front end alone, but you really wouldn't drop much weight with only losing the AWD Tcase. Programming could turn off the AWD sensors.
I don't think its worth doing.
youd also have to change the output shaft in the trans, and the tranny crossmember. I dont think there are any sensors that youd have to worry about. youd have to do some work on the front spindles, the spindle from a 2wd sub/tahoe/avalanche would probably make it the easiest to do.
I dont think it would be worth doing either
Old 01-05-2004 | 04:04 PM
  #23
MNC5's Avatar
Did you actually think I came up with that
FlowmasterMufflers
08-14-2015 01:04 PM
cammed06
07-24-2015 12:09 PM
FlowmasterMufflers
07-22-2015 01:29 PM
FlowmasterMufflers
07-09-2015 12:23 PM
NuckenFuts
07-09-2015 08:45 AM
Quick Reply: How to dyno tune an SS?
