How to fill transfercase?
Okay...laughing aside, the fill plug is about 4" above and to the right of the drain plug on an Autotrac case right?
Well I can't seem to get more than about half a quart in the transfer case.
Is there some trick to filling the case up? Maybe a fill hole elsewhere?
Thanks!
Thanks!
Re: How to fill transfercase?
I know it is not full as I drained 2 qts out and only could get 1/2 of a qt in. The only thing I can think of I must not be getting it completly in the hole...like I am hitting the side of the hole with the fluid and that is why it keeps coming out. I did peep inside with a flashlight and could barely see in there.
I have decided to just say screw it, and get the trans place to finish filling it up along with installing the servos. I can't drive it anyway right now.
Anyway, thanks for you help man...I appreciate it!
Try looking in there with a flashlight and a mirror. Maybe there is a gear or something right in front of the fill hole. Maybe if you hold the hose at a different angle it will help keep it from running back out. I just put a gear oil top on the transfer case fluid bottle and filled mine that way. It was a bit awkward but it worked. I think that I had a short piece of clear hose on the end of the gear oil top as well but maybe that was for the front diff which was even harder to fill if I remember correctly.
what a rush!
Thanks!
Thanks!
If you want I can read my service manual and see what it says......
