how to gut out cats?
niiiiccceee , i like the mr.crowbar idea, i talked to a guy at a muffler shop down the road he said hell cut em off and put tubing in its place for 80 bucks, im also gettin a spintech 3in/3out, with it dumped maybee, wonder how thatll sound...me likes to wake the neighbors.hehehe
Originally Posted by 99silveradoSS
Will gutting the cats make the exhaust flow unsteady and cause a lot of turbulence?
I got a hell of alot more exhaust tone. I don't like it around 2500rpms becasue it pops and sounds like ***. I am going to true duals and an xpipe when I get the 300 dollars. 80 dollars is exactly what it cost me to get mine cut off. watch out for the passenger side cat. it's a bitch to reseal after you cut it off. very hard to seal the top.
The shell that used to be full of zirconia is now
a resonator and it may make a note you don't
like. Usually resonators are meant to mellow it
out but an undesigned one might worsen things.
The cats surely do muffle the pulse nature of
exhaust, capillary-tube mufflers with some
chemical activity is what they are.
If you need to worry about visual inspections, you can have a pipe welded through the cat housing so that it still looks stock but flows straight through. And yes, there is a lot of turbulance from gutting the cat housing out that screws up flow.
bagged7104SS
22
10-24-2015 06:14 PM
