How high can you safely rev an '04 4.8L?
Old 05-05-2005, 10:55 AM
Destroyer of Transmissions
1SlowHoe's Avatar
I have a built tranny coming. Hopefully I will be able to shift as you say, I just e-mailed my builder and asked. What I was really wanting was for mine to be able to shift into overdrive at WOT. How can I make that happen? Right now, with the stock tranny, I have to get off the gas to get into overdrive, or maybe I just haven't left my foot in it long enough to see.....
Old 05-05-2005, 01:23 PM
zippy's Avatar
i'd say the stock lower end in a 4.8/5.3 is good for around 6700 or so safely. the valve springs however are only good to around 6200 or so in stock form.
Old 05-05-2005, 01:26 PM
Deckhand's Avatar
Originally Posted by hirdlej
Are these motors really that tough? I was thinking with the goofy oil pumping system we have with that long *** pickup tube and the concentric oil pump on the crank that these are weaker than the old style chevy smallblocks (i'm used to that old technology) Or am I wrong? Not trying to dog on these motors, I own one myself I'm just wondering how tough these things are compared to the smallblocks of yesteryear that I am so familiar with.....
Thanks already for the great input.
Joe
I'd rather own a 4.8L GenIII motor than a 350 SBC.
Old 05-05-2005, 01:32 PM
SSlow 4.8's Avatar
Amen.
Old 05-05-2005, 01:41 PM
FILE's Avatar
Tell that to Randy.....
Old 05-05-2005, 02:23 PM
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
01Thunder on the dyno spun his up to 7200rpm thats with a stock bottom end and the valvetrain replaced with quality parts though. All the speed shop have said 6100 and under for stock internals and the bottom end is good till about 6800.
Old 05-05-2005, 02:42 PM
zippy's Avatar
LOL, i don't think he's concerned about safely. if his lets go he'll just go bigger most likely. i wouldn't be nervous turning one 7200 or so if it were my own, but to say that some else's can go that high is a touchy area. the guys with the 5.7's and T-REX cam's are turning their bigger cube motors higher without much problem. after 6700 i'd personally say it's a let'r fling issue and don't cry if it breaks.
Old 05-05-2005, 03:19 PM
kbracing96's Avatar
The 4.8's have a lot shorter stroke and longer rod then the 5.3-6.0. I believe its a 3.26 stroke, which makes for a high rev potential motor. Plus it has the 6 bolt mains like the rest of the gen3 motor's. Like the other members here have said I think you have more of a limiting factor in the valve train then the bottom end.
Old 05-05-2005, 04:00 PM
GoldenVelvet's Avatar
The 4.8 has a ridiculously short stroke (for being a V8). Stock the valve springs are the limiting factor. Upgrade those and you can REV the lill' 4.8 high. Being that its still a push rod motor you can put a 'Rev Kit' on it (a rev kit is a second set of valve spring on the lifter valley) though I dont know of anyone making one for the gen3's yet. I dont see why a mildly upgraded on cant rev to the 8-9K range (No joke).
Stock I would keep it in the mid 6K range with out better springs.
Old 05-05-2005, 04:43 PM
Keith's Avatar
Especially with more crank journal to rod journal overlap, the crank should be stronger than those in the 5.3, 5.7 and 6.0.
Quick Reply: How high can you safely rev an '04 4.8L?
