How to install trans cooler on a truck that doesn’t have a stock cooler
How exactly do I go about installing a transcooler on my 03 1500 with no stock transmission cooler? Do I run new lines from the tranny, and radiator back to the new cooler? Thanks
okay! How would I go with bypassing? Just run the lines straight from the tranny to the cooler. Then just cap off the radiator?
darkirish63 (06-11-2020)
i am going to use a Hayden 679. The biggest then offer. It is like 50$
100% Redneck
If you need to cut the OEM lines use a flare tool to put a flare on the line. This will help keep the clamped rubber hose from blowing off under high pressure.
Like posted above ^^^ spend the extra dough on the 40K. I had a Hayden 1403 (slightly smaller than the 679) supplied by my transmission builder (required for warranty). On hot summer days I would see 200* plus. While higher temps won't immediately hurt the transmission over time it will slowly cook the seals, o-rings and fluid.
Hayden 1403
![-cd7fgzi.jpg](https://www.performancetrucks.net/forums/attachments/gm-engine-exhaust-performance-21/153978d1683126171t-how-install-trans-cooler-truck-doesn%92t-have-stock-cooler-cd7fgzi.jpg)
Tru-Cool 40K
![-1kumhch.jpg](https://www.performancetrucks.net/forums/attachments/gm-engine-exhaust-performance-21/153979d1683126171t-how-install-trans-cooler-truck-doesn%92t-have-stock-cooler-1kumhch.jpg)
Hayden 1403
Tru-Cool 40K
The following 2 users liked this post by RedXray:
3wide (06-12-2020),
darkirish63 (06-12-2020)
