How to know the Year of an LQ4 engine ???
I bought one but now I'm not sure that the guy told me the truth... There is any way to know the year of an LQ4 engine ??? what part numbers should I check ??
Thanks guys
P.S. I'm also looking to get a set of Rod/Pistons from a '05+ LQ9/LS2 and the crank too...
Thanks guys
If you have EGR you'll need to remove it to be able to see the pad on the block with the casting #s. But I dont think that necessarily guarantees you the model year of the engine. I believe GM had at times or maybe all the time had surplus of engine blocks. After removing the EGR I found my block was cast in May 2001, yet it's an 02 engine, and unless I'm mistaken, production for the following MY doesn't begin until september, october...
