How to Make E-Fans Come on After Turning Engine Off
Was wondering if there was a simple way to make my e-fans cool down the coolant and engine to a specific temp after shutting off the ignition and walking away?
Jim
Jim
11 Second Truck Club
Originally Posted by bluecajun5.3
toggle switch is the only way i know of. get a two prong toggle switch, run one wire to power source and the other to tap in to pin 42 to ground out the pcm.
There is a setting in Hptunners. Ignition off "disable temp" and "run time". I have mine set to run for a minute after the I shut the truck off.
But to make it really affective you really need an electric water pump.
I guess there is no way to do it that way on my truck.
I would like to have them run for a 60-90 seconds after truck is shut off like yours does.
Does it do it everytime the ignition is shut off, or when the PCM detects a normal operating temp? I would rather it not cycle everytime it is keyed on then keyed off.
Any insight on this?
Jim
Originally Posted by 99Silver6.0
Doesnt the Dakota Digital controller have that feature built in??
That's why I'm asking how to make it do what I want it to do.......
Anyone else?
Jim
How do I change this text
Have nelson change your fan settings as joshluther said... It will only run if the coolent is over the "disable temp" and will only run for the time selected in the "run time" tab. I think that is as close as your going to get unless you add some type of controler.......
Jim
