how to make truck run 13s?????
#23
Re: how to make truck run 13s?????
well can yall tell me where to get the 6.0 and wut all i will need and wut i should do to it while its out of the truck???? should i just put it on a stand and build it ???? i can have 2500 bucks then jsut enough for a drop so let me know i just want to spank some ***
#26
single digit dreamer
cobra99vert for AIM
6.0 will bolt right in, it is externaly identical to the 4.8/5.3. not sure about emisions but i think it will have less of an effect than a cam swap. lots of stuff that would be nice to do while you had the motor out but if your limited to 2k then forget about it. i got my heavy truck into the 11's with a STOCK 6.0 so you dont really need to beef it up right away.
best place to get a motor is right here, they come up for sale every few weeks. if you go 6.0 you must get a 2001 or newer, it will have aluminum heads on it, if you are not 100%sure of the year get a pic of the crank flange and post it and we will tell you if it is the right year.
i really think for your stated budget a 6.0 is your only hope unless you are willing to spray it.
#27
13 Second Truck Club
Location: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
1 Post
Pewter03GMC is sellin a 6.0 for $450, missing some stuff you'll want to build up anyways
#30
One more vote on a 6.0 swap, but I'd leave off the headers for now and get a converter. That would definitely put you in the mid 13s. It is no extra work to install a converter during the motor swap. Otherwise, you'll have to pull the tranny later to install it.
