how much does 3inch exhaust tips change the sound?
hey so i use to have my true duals 40 flows dumped before the axle with no tips just the flows ending it and now i had the exhaust all redone true dual
40s angled out back with 3inch tips and i dont like the sound it sounds like glasspacks now does the big tips cause this and will cutting tips off help because before it had a real mean agressive sound .what some of ur guys of opinions thanks mike
Usually the tips make it sound louder, but I quess it was louder dumped with the sound reflecting off the road. My truck has a better sound with tips, but I am currently not running any.
thanks which my exhaust doesnt sound like flowmasters anymore it just sound like glasspacks i dont dont which now i can notice and misfire in bank one what can cause that new plugs and wires coils good and o2 s are good
Banned
I think they tighten the sound and make it crisper. Maybe even a little louder
Running the muffler straight with no turndowns seems to be deeper. But I think the exhaust might burn stuff.
The trans am style turndowns are stainless steel made by pypes.
I just want to try something different. I think a pair of big wazoo tips will make the tone deeper. Old street rodders called those style tips echo cans.
PT's Slowest Truck
You could try dumping your current exhaust and it will get louder, but it won't sound like the Flows...Flowmasters are pretty distinct in their sound.
As for your misfire, if you know that spark is good, O2's are good, I'd take care of the basics first. Check compression to make sure that there's nothing mechanical, and if that's OK, check fuel pressure, or you may have a bad/clogged injector. You could try running some injector cleaner through it or swapping injectors from one cyl to another if you know which cyl is misfiring at this time. If you swap that injector to another cylinder and the misfire follows it, the injector is at fault.
thanks for all the replys which i still have the flows on it it just sounds like glass packs which the misfire goes away after engine warmed up and its a weird clacking sound o out the drivers side tip until warmed up
thewrx
08-12-2015 08:28 PM
V-seriesTech
07-28-2015 12:31 PM
FlowmasterMufflers
07-09-2015 11:35 AM
