How much horsepower can the 8.1 42lb injectors hold??
Did some caculations on the 42lbs
At 50psi fuel flow is 40.69lbs
Running at 80% duty cycle you can get 473 hp at the crank.
This is with a blower.
You can raise the fuel pressure or up the duty cycle for more.
60psi fuel + 90% duty cycle gets around 525rwhp
Without a blower the # are way different.
I think its right
From racetronix site
Part Number 17113739 (OE Part # 25176061) *** Direct fit for short G.M. LS1 SUV injectors ***
Static flow @ 37.95lb/hr @ 43.5PSI / 300KPa (4.31 g/s = 398cc/min)
Static flow @ 43.82lb/hr @ 58PSI / 400KPa (4.97 g/s = 460cc/min) *
Dynamic flow (2.0ms/10.0 ms(pulse width / rep rate)) 6.0 lb/hr @ 43.5PSI (0.748 g/s @ 300KPa)
Coil Resistance: High Impedance / High-Z (No ECM driver modifications required)
Ball/Seat Design with 3-Hole Diffuser Disc - Pencil stream
I think its right
