How much hp can a stock 4L80e can hold??
^true the overdrive is stronger an the oil cooler stub outs on the right side are spaced out to front an rear for better cooling instead of together my 02 2500 gmc 6.0 held 450 to the wheels with cam an a single wet shot!
If you can get a low mileage unit with a shift kit and a big trans cooler then you should be good unless you beat on it all the time. Basically any built 80e from a reputable builder should get it done.
4L60E to 4L80E Swap, Attention 4WD Owners with Superchargers
What do you think about that output shaft?? Is that any good??
I was told by a local mechanic that that was the way to go..
zaathur151
07-06-2015 10:57 PM
