How much power do you guys think I can build?
There is nothing wrong trying it the way you are, but if you do decide to go on the hunt for a AWD front differential, all the GMT-800 Yukon Denali's and Escalade's (AWD versions), not to mention the Sierra C³'s came with 3.73's. The front axle from a Yukon Denali or Escalade would obviously be the easiest to locate.
I gotta bump this up. I was talking with a coworker of mine explaining my build. Turbo, 4L80E, Trutrac, AWD etc.
Well, he swears I'm going to blow everything up. The transmission won't hold, the drivelines will break, it's only a 10 bolt so that's going to explode, and let's not mention the front end, no way that's going to take it! It's the tiniest front end ever!!
Basically, I got laughed at.
What do you guys think? Think I'll break everything?
Well, he swears I'm going to blow everything up. The transmission won't hold, the drivelines will break, it's only a 10 bolt so that's going to explode, and lots not mention the front end, no way that's going to take it! It's the tiniest front end ever!!
The 4L80E with a Transgo HD-2 shift kit would laugh at you, asking for more power.
The 10 bolt at that power will be fine, the factory G80 will let go sooner or later. Upgrade to a Tru Trac and you're fine.
I'm not too knowledgeable on front diff stuff as I've never owned a 4x4, but I see many members here clicking off 10 second, some even in the 9 second range launching in four wheel drive and the stuff seems to hold up.
Do it, prove him wrong.
HAHA! This made me laugh out loud!
Actually, he's sort of a jeep guy.
All I'm planning on doing to the 4L80E is the hd2 shift kit. I was actually wondering if there's something else I should do before I put it in. I've also got a 40K trans-cooler.
I forgot to mention that I'll be running a Yank SC3000 stall as well.
My factory rearend is open. I bought the trutrac already and all I need to order are ring gear bolts. I've ready got bearings and shims. I shouldn't need to buy heavy duty axles or anything should I?
Basically I'm going to put it all together and see what happens. I don't think I'll break anything and if I do, I'll repair it as needed.
