how much spray do i need to beat a lightning?and LS1 Fbodys?
Truck addict
you can run nitrous on a stock tune. since stock timing is relatively low you should be fine. in fact, my custom tune is running stock timing. which sucks for daily driving.
but to beat a stock L, most of the stock ones run mid 13's in the heat!!!!!!!!!!! i have a vid in the multi section of a run i had against one and it ran a 13.7 on an 80 degree night. only mod was a filter. so, if you spray a 100 shot and assume you lose a second, where does that put you?
Originally Posted by Ruffrider5.3
Depends on what the lightning or fbody is running. My stock Fbody went 13.3 in the 1320. Stock lightnings go from 14.0 to 14.50.
i have 2 friends who both ran 13's with their stock lightnings, one a 13.8, and one a 13.7, ive even heard of people getting 13.6 with a stock one.
I would say 125 shot of laughing gas AN ADDICTING liquid also a good tune is going to take care of them FORD L things. That's to be on the safe sideuse no more than 125. I'm SPRAYING 150 shot in my 5.3 STOCK internals and i dont have any problem taking care of them L-s with out letting the full dose out...
2004 Chevy LS
RC/SB
LM7 5.3L
4l65E w/SHIFTKIT,SERVO
G80 w/3.73
ADD ons: LS1 electric Fans,TB bypass, TB spacer, 160* Thermostast, K&N Cold air induction, Borla ProXcess Muffler w/Turndows, NitrousWorks 150 shot, HP Tuners Tune, 295/50r16 BF GOODRICH radials.
Future Mods 6.0L, patriot 5.3L Stage 2 head and cam kit, Vigilante stall, 4.10 gears Longtubes and OFY pipe, TNT N2O set up.
AGGRESSIVE MOTORSPORTS live life at full throttle......
2004 Chevy LS
RC/SB
LM7 5.3L
G80 w/3.73
and how many runs will my tranny hold ? i dont really care cuz once it goes off im probably putting a 6.0 in along with a 80e. anyone have a link to a kit ?
No you don't need a tune. Get plugs, wires. You may nned a tuner to adjust your rev limiter and shift points. You should then be in the 13's maybe but I still dont see you beating an Fbody. Mine ran 13'50's bone stock 500 miles on it.
Originally Posted by fogle04
i ran a 125 on mine with stock plugs and using a granetelli programmer. the truck loved it. picked up .9tenths in the 1/8th spinning to 60'
Affirmative!! Stock L"s run consistent mid-high 13's all day! Seen plenty of them do just that! The 01-04's are the ones with the new tweak in power(380hp) and the 3:73's. The 99-00's run the 3:55's with 360hp! Torque was almost the same!
Originally Posted by 2000_Silverado_SS
You've got a really nice looking truck there. What will she run in the 1/4?
