How much transmission fluid does your truck burn?
Old 05-29-2005, 09:18 AM
PT's Slowest Truck
budhayes3's Avatar
Originally Posted by KySilverado
Just a little incline will make it check wrong. Good level surface when checking it?
I was just gonna mention the same thing...also, make sure that you check it at the same temp as the last time. The level will rise as the vehicle heats up and the fluid expands. The trans temps may have been warmer the first time you checked it.
Old 05-29-2005, 10:57 AM
NovaTime's Avatar
I always check on a good level surface. The level wasn't low enough to cause damage, but enough to annoy me. I usually check after the car has been running for a while. The ambient outside temperature was around 65 and it was raining, so it may have cooled the drive train quicker than I expected, especially with an external cooler.
Old 05-29-2005, 06:41 PM
NovaTime's Avatar
I checked again and the level was where it should be. I guess I was going nuts.
wrb002
08-31-2015 12:00 PM
MileHighSierra
07-22-2015 11:19 PM
black6spdz
07-16-2015 01:32 AM
ROB 1 TON
07-13-2015 04:43 PM
Nimoryan
07-05-2015 03:50 PM
Quick Reply: How much transmission fluid does your truck burn?
