How to put a switch in Nelson 3-Relay harness?
Shouldnt there be a wire connecting to the relay plug that controls high for that particular fan? Why couldnt i splice those wires and run them to a 3 prong switch with hot and ground? I want to use an on-off switch with three prongs on the back. Is that possible?
I have a gauge for that
when its flipped up, the fans are on low, when its flipped down they come on high.
an issue with this would be you can still turn the fans on low with the engine off, by grounding the green wire. I have mine wired this was so i can run my fans to cool off my engine bay with the engine off, but to be safe to make sure you dont accidently run down your battery, you can put a relay on the green wire to only close when there is accessory power.
ARC
57
02-21-2022 10:54 AM
ullose272
07-19-2015 04:14 PM
