How to put a switch in Nelson 3-Relay harness?
Old 07-26-2010, 09:09 PM
02'Z71ONDUBZ''s Avatar
Shouldnt there be a wire connecting to the relay plug that controls high for that particular fan? Why couldnt i splice those wires and run them to a 3 prong switch with hot and ground? I want to use an on-off switch with three prongs on the back. Is that possible?
Old 07-26-2010, 09:12 PM
I have a gauge for that
Atomic's Avatar
yea if you use diodes
Old 07-26-2010, 09:20 PM
brent5631's Avatar
Also since this is a nelson harness, Atomic would your wiring diagram work since the A/c relay is triggered off of a positive signal not a ground.
Old 07-26-2010, 09:46 PM
Atomic's Avatar
Im not sure if that version connects to the pcm or not, or just the ac wire, but this should work
Old 07-26-2010, 09:52 PM
So which relays and wires control the high stage on the fans
Old 07-26-2010, 09:53 PM
brent5631's Avatar
Yeah. I was thinking of the two pin harness at first and forgot that the A/c relay triggers positive. That new one should work.
To control High on both fans both relays have to be triggered.
Old 07-26-2010, 09:57 PM
Atomic's Avatar
when its flipped up, the fans are on low, when its flipped down they come on high.
an issue with this would be you can still turn the fans on low with the engine off, by grounding the green wire. I have mine wired this was so i can run my fans to cool off my engine bay with the engine off, but to be safe to make sure you dont accidently run down your battery, you can put a relay on the green wire to only close when there is accessory power.
Atomic's Avatar
ARC
57
02-21-2022 10:54 AM
Go5.3tt06
09-12-2015 09:29 AM
Ammadien
07-22-2015 08:50 PM
ullose272
07-19-2015 04:14 PM
01sierraon22s
07-08-2015 11:26 AM
Quick Reply: How to put a switch in Nelson 3-Relay harness?
