How should i redo my exhaust?
I like that idea. A 3.5" single will flow the same as dual 2.5" and save you the complexity, cost and weight of a dual system. The only problem you may have is the noise level under boost if you use straight through mufflers.
TOTM: January 2007
I went with a true dual set up. I have TOG's too. I bought a 2.5" madrel bent SS y-pipe from Oxidizer. I used Magnaflow metallic cats 2.5" in/out into an x-pipe. Mandrel bent 2.5" aluminized steel from the x-pipe back into a SS magnaflow 2.5" dual in/out. I just passed SMOG about 3 weeks ago here in NorCal.
Here are some pics:
Here are some pics:
gaps
10-15-2015 02:53 PM
Superman09
09-25-2015 05:55 AM
