How should i redo my exhaust?
Old 12-16-2007, 11:38 PM
laynlow77's Avatar
video fixed.
Old 12-17-2007, 08:24 AM
Resident Retard
BlackGMC's Avatar
IMO I would do 3in" off the collectors into a Y-Pipe, then 3.5 into two Magnaflow mufflers in series then dump it over the axle....
Old 12-17-2007, 09:56 AM
kw05silverado's Avatar
im selling a 2.5" x pipe for 40 bucks. pm if u want.
Old 12-17-2007, 08:10 PM
Stoichiometric's Avatar
I like that idea. A 3.5" single will flow the same as dual 2.5" and save you the complexity, cost and weight of a dual system. The only problem you may have is the noise level under boost if you use straight through mufflers.
Old 12-17-2007, 08:29 PM
Resident Retard
BlackGMC's Avatar
This might help. Did a little math and compared stock pipe size to various other configurations. Dual 2.5 and single 3.5 have roughly the same volume.
Old 12-18-2007, 11:22 AM
TOTM: January 2007
Last Call's Avatar
I went with a true dual set up. I have TOG's too. I bought a 2.5" madrel bent SS y-pipe from Oxidizer. I used Magnaflow metallic cats 2.5" in/out into an x-pipe. Mandrel bent 2.5" aluminized steel from the x-pipe back into a SS magnaflow 2.5" dual in/out. I just passed SMOG about 3 weeks ago here in NorCal.
Here are some pics:
flatblack83
03-28-2021 10:28 AM
kha4079
10-29-2018 04:38 PM
gaps
10-15-2015 02:53 PM
Superman09
09-25-2015 05:55 AM
03sierraslt
09-06-2015 06:53 PM
Quick Reply: How should i redo my exhaust?
