how to tell if your injectors are maxing out???
#41
well I moved my injector flow rate from 3.06 to 3.18
and now it went way rich...
what happened there?
3.18 is stock setting is it not?
plus once I did this I couldnt get it to idle for ****..
idle was way down to around 650-700 even tho I had the table set to idle damn near 1,000Rpms
what did I do wrong?
#43
Look for another issue. Going from 3.06 to 3.18 should lean it out just a bit. You should be making changes to your PE table. That way you can lean it out at WOT for a specific rpm range. Adjusting the injector flow rate will make a global change.
tooquick - is that a dry or wet shot? If its dry, them more pressure or larger shot will make make you use more injector. If its a wet shot, it will make minimal difference.
#44
Adjusting the IFR will make a global change and should bring down the LTFT's all around. And by what you were saying, weren't you pretty + on most of the fuel cells in part throttle??
Did you get a chance to mess with your TPS thing again yet?
#45
gaps
10-15-2015 03:53 PM
Pontiac Derek
09-19-2015 02:49 PM
