How would this cam work in my 6.0?
Old 09-03-2011, 02:48 PM
FL_Cracker's Avatar
Originally Posted by 07 Z71
i say u get ur heads worked and milled before u put that cam sir and a big stall at least over 4k
How much should i get milled off of them?
Old 09-03-2011, 05:48 PM
AndysC3's Avatar
either TSP 224 112, or the TR224-112 will be what you are looking for IMO.
Old 09-03-2011, 11:52 PM
TOTM: June 2007
bgray's Avatar
There are so many question needed to be asked
Does ur truck have stock size tires? If no what size?
Do you daily drive it?
Do you tow with it?
Do you have other mods?
What size stall do you intend on using?
What size injectors do you have?
Old 09-04-2011, 12:12 AM
Baltimore Whore
Mangled03gmc's Avatar
Bottom line on choosing a cam, is how big of a converter do you want to run, what you do with the truck?? Once you get that figured out then you can start getting some ideas of where the cam should be... That is a donkey dick cam, unless you going to run a verter 4k your leaving alot on the table.. That is alot for stock heads as far as what they can handle flow wise..
OHsixLS3
12-27-2016 09:30 AM
all_individual
10-10-2015 10:09 PM
steves86ta
07-28-2015 10:21 AM
Suburban2500
07-19-2015 04:50 PM
all_individual
07-13-2015 11:01 AM
Quick Reply: How would this cam work in my 6.0?
