How are you keeping under hood temps down?
After seeing 140+ temps on my MAF on our first 65 degree day here I knew I needed to do something!! Well I went and bought a 30"x12" roll of thermo tech fiberglass with a foil type reflective backing on it. It supposed to be good up to 1500 degrees.
I wrapped it aroung the intake tube on my STS kit with the reflective side out and secured it with some safety ties. Its not really that close (about 3-4" away) to the exhaust manifold but my fear was that the metal tube was being heat soaked and the MAF may have been getting a false reading.
So far I have not seen temps above 90 degress after doing this, but have not really hammered on it for a long distance either. I know there are some pretty slick lace up type of heat sheilds out there but seemmed a little on the pricy side for my blood.
I'll post some pics of my ghetto set-up later today.
Anybody have pics of what they have done please post em up!!
14 Second Truck Club
I was thinking of doing the samething. I'm also going to relocate the MAF up by the TB now that i have the E-Fans and have the room and get it away from the exhaust.
The heat sheild works great though from what I've seen so far, I just have to make it pretty now.
The place I got it from had huge rolls of the stuff, it was $25.00 bucks for the peice I bought. I would get a little wider peice if I had to do it again because it does not make it around the MAF where the plug in is.
Maybe a 15-16" wide peice would make it.
Where you get the stuff from? Realy not much modification needed on the kit. Just have to lengthen the wires to the MAF.
Originally Posted by TG02Z71
I bought it at a local high perf supply shop. They sell all high performance stuff, no cool looking things or cosmetis items just high perf. I'll go out and take a pic of it in our lot and post it in a few minutes.
Ok heres some pics, I know it looks major ghetto!!
It will have to wait to be done pretty. I also started wrapping my exhaust up to the turbo with thermotech tape I had laying around from a project I aborted about 10 years ago...lol.
I'l probably eventually rotate the reflective wrap on the intake so the gap is underneath.
Originally Posted by kbracing96
Jerry, you won't have to cut the MAF wires, I put my intercooler on a couple of weeks ago and was able to just cut the tape off the wiring harness and pull the wires out of it. Had plenty of length to put the MAF on the driverside, front of the motor. HTH.
