HPTuner arrived. Question
Old 01-25-2005, 02:49 PM
  #51
marc_w's Avatar
The 15-105 thing... Thats "dynamic cylinder air"........or how much air the motor is pulling in in grams per cylinder...
I don't know what those values are in the IFR table. 0 vac through 80 vac. I guess you'd look at what your MAP is reading and correlate between the two?
Old 01-25-2005, 02:54 PM
  #52
900Z1's Avatar
Originally Posted by Flyer
Lower the injector flow rate a little. Make little steps, about .5 if your using the Standard measurements, or .10 if your using imperial units.
Do I adjust all of the 17 different numbers by .5 then log, or do them 1 at a time
24.8 24.8 24.8 24.8 24.8 24.8 24.8 24.8 24.8 24.8 24.8 24.8 24.8 24.8 24.8 24.8 24.8
Old 01-25-2005, 03:36 PM
  #53
marc_w's Avatar
All at once...
Old 01-25-2005, 03:42 PM
  #54
marc_w's Avatar
Actually, by .5 would be a HUGE change. It would make your PCM thing you were running 12lb/hr injectors...
(EDIT - Sorry, I thought you were going to MULTIPLY by .5!! Just subtracting .5 would not be a problem at all.)
Mine are similar injectors (24.something), I had them scaled down by like 94.6%... so I had them multiplied by something like .946.... which had the system thinking they were about 23.8lb/hr.
My fuel system is different from yours (returnless or something like that), so I'm running a "non linear" IFR table, but here is my data:
22.57 22.69 22.88 22.94 23.07 23.25 23.44 23.56 23.62 23.81 24 24.12 24.18 24.55 24.68 24.93 25.05
Old 01-25-2005, 05:06 PM
  #55
Flyer's Avatar
Originally Posted by gamedawgx53
speaking of the IFR table
whats "verticle" along the left side 15 thru 105 in the histogram (LTFT)
...is that the #s that correlate with the 0 thru 80VAC found in editor?
and if so anything above 80VAC is dealt with here correct?
Engine>Fuel>Power Enrich>PE Enrichment>V8 Mult vs. RPM
That is vacuum, or other wise known as MAP readings in kpa.
The g/cyl is for timing/retard histograms (still on the left column).
The LTFT histo correlates to the VE table.
Old 01-25-2005, 05:07 PM
  #56
Flyer's Avatar
Yes .. be sure it's subtract, and not multiply. I guess I should have been more clear about that.
Old 01-25-2005, 05:31 PM
  #57
900Z1's Avatar
I made 2 more logs..Did the subtract .5 on each log. Last log had some in the
red (+9 ) so it came down some, I noticed 7* KR while logging the last time
the time before that it had 4*KR.
Ate a bowl of soup all day yesterday and 1 sandwitch today. If it takes me
very long to tune I'll be a skinny little bastard.
Might take a day or two off so my eyes can uncross.
Old 01-26-2005, 08:37 AM
  #58
You could just change the fuel and timing advance tables ABOVE 2400rpms.
In the fuel part add .75(since you've already taken away .5) and up the timing to 30* max starting at 3200rpms. This will give you pretty much stock tables for low part throttle, but when you hammer it it'll jump to the next higher part of the table and run like crazy. If your KR increases when you pull fuel, try keeping that timing first and add fuel to match it. If that doesnt work you may have to pull some timing.
Old 01-26-2005, 12:35 PM
  #59
Flyer's Avatar
Snake .. you lost me .. Where are you adding fuel? Why so much timing on a stock truck?
Old 01-27-2005, 06:03 AM
  #60
900Z1's Avatar
Slowly learning. Finding out there is more fuel at the TQ curve and less at the HP curve.
I knew there was a curve back in my mind, but never thought about it when I
started with HPTuners
There is light at the end of the tunnel, but It's a long ways off. At least I can see the light. Much better than it was 2 days ago.
Figure in a week or so I will have a tune that works good.
Just can't spend all day on it. Got to get ready for son's homecoming party.
Thanks to marc_w,FLYER, Chris and all others that helped.
John
Quick Reply: HPTuner arrived. Question
