HUGE problems, need help ASAP
#36
Yep, normal oil pressure and no voltage drop besides the lack of idle speed for the alternator to run good.
****, ive gotta go to work guys. I'd really appreciate it if you guys kinda debated this out and ill check back later
Checked the oil dipstick and it still looks fine, no coolant loss that im aware of. the front spark plugs on each side (easiest to check) look fine, and it will hardly even hold on idle now. It is progressively getting worse. I have a whole nother set of coils to try if I need to, but it is throwing a multiple random missfire code. I will drop the tank and drain it when I can and see if that was it. I also have a good set of injectors to swap over if I have to.
thanks alot guys
thanks alot guys
