HUGE problems, need help ASAP
#62
Those handheld temp guns are money. I picked that trick up from my cousin's engine builder for his circle track race car. Anytime they get a misfire or something isn't quite right, the temp gun always tells which cylinder(s) are significantly colder than the rest. Glad that was of use to you.
#65
your fuel pump could still be going out though mine went out in like 45 to 55 k got it replaced under warranty and have almost 112 k on it now. also if you did run out of gas you sucked all that crap at the bottom of the tank up too so keep running the cleaner thru and check the filter you just put on it may be full of crap again. at least thats what i would do lol
#66
I'm also gonna change plugs more than likely.
