I am finally moving on, picked up a LQ9 yesterday for the truck
Old 11-16-2010, 05:43 PM
  #31
Fastest D1 Procharged Truck
02_Orange_D1SC's Avatar
Originally Posted by BlackGMC
i don't know about being the master, but i have experimented alot with this little motor. It was definately a learning experience, but a costly one.... So far i am about even on money... A Heads/cam 4.8 costs about the same as a Cam only 6.0... the sad part is i will be faster in the 6.0 and get better MPG....
yeah thats what i ment that you've spent alot more time then most people on here would've on a 4.8. thats why i think im throwin in the towel on mine i was goin do to a heads and cam 4.8 but like you stated you'll get more hp and tq from a 6.0 plus its about the same price.
Old 11-18-2010, 09:06 PM
  #32
Custm2500's Rude Friend
1FastBrick's Avatar
What year was the VHO? Why did he pull it? and how many miles on it?
Old 11-20-2010, 02:21 PM
  #33
Resident Retard
BlackGMC's Avatar
The motor is all cleaned up and ready togo. Except i need two bolts. One valve cover bolt and one of the long oil pan bolts. I accidently dropped one of the cam retainer bolts into the oil pan when i was swapping out the cam. So the pan had to come off. When i was putting the pan back on one of those long bastards snapped. Oh well i will just pick up another one sometime. Anyways here are so pics.
Old 11-20-2010, 02:26 PM
  #34
fortplainman's Avatar
looking good, should be pretty bitchin when its all buttoned up.
Old 11-20-2010, 05:23 PM
  #35
PT's Slowest Truck
budhayes3's Avatar
Circled converter came in today . Now i can wear my CircleD tshirt with pride.
It's a comfortable shirt, I wear mine whenever I'm not wearing my Finish Line Transmissions t-shirt
The engine looks good Corey, aside from the block and valve covers, it looks like you painted the oil pan and timing cover also?
Old 11-20-2010, 05:27 PM
  #36
fastnblu's Avatar
It came out of a buddy's vho. As far as plans, i am putting in a 220/224 .581/.582 115+4 and a circled 278mm 2a TC. I have not really decided if i want togo further cause i want to start building a race car. If the race car idea does not happen then i will toss a tvs1900 and redo the exhaust for bigger headers.
How many miles, & why was it pulled from VHO?
Originally Posted by skeet
...i take it the parts you mentioned on order are working around the tvs?
I didn't see this coming.
The motor is all cleaned up and ready to go. Except i need two bolts. One valve cover bolt and one of the long oil pan bolts. I accidently dropped one of the cam retainer bolts into the oil pan when i was swapping out the cam. So the pan had to come off. When i was putting the pan back on one of those long bastards snapped. Oh well i will just pick up another one sometime.
I did the same on my cam swap, sorta. I replaced the timing chain, well to do that I had to take down the oil pump pickup tube. I could get the bolt off the pickup, but not get it started w/. oil pan on.
I dropped it in pan a few times, lucky for me I was told I should drain oil 1st. Otherwise, I'da had to take the pan off after emptying it anyways searching for that lil bolt. I was forced to lower pan, I get all the bolts torqued on pan after reassembly, all that's left is those pricky lil long bolts. I had a little oil on them & as I torqued em, thought it was taking too much oomph. I TQ'd em at the m6 bolt spec not the m4 (almost double). So the right broke off 1/2-3/4 into block. And that's how it sits. And will.
Only way it'll get removed...is if a 6L goes in its' place or I can allow the downtime on my 5.3 next yr. (not likely).
Old 11-20-2010, 05:49 PM
  #37
Resident Retard
BlackGMC's Avatar
Yep i painted the timing cover, valley cover and oil pan with cast alminun engine paint. I was skeptical when i bought iy but i was really surprised after i painted that stuff
Old 11-20-2010, 05:59 PM
  #38
charcold-bowtie's Avatar
U want me to mail u bolts?
Old 11-20-2010, 06:05 PM
  #39
fastnblu's Avatar
Corey, I've been havin problems posting on PT for almost 15 min., in fact, somehow even tho I posted before Billy, his post showed up 1st. Go figure. Anyway, how many miles, & why was it pulled? Was there a problem? Congrats!
Old 11-20-2010, 06:13 PM
  #40
PT's Slowest Truck
budhayes3's Avatar
Did you get the paint from Eastwood? I've seen that type of paint in their catalog...
Don't feel special Tom, I was getting database errors here too...and how do you know that you posted before me? Pretty sure that my post went up before the server went down...
Quick Reply: I am finally moving on, picked up a LQ9 yesterday for the truck
