i bet no one else in here has one of these(yet)
Originally Posted by parish8
it can be if that is how you want to set it up. i dont see needing it that way. what i do see is using it as a staged set up so i can pick how much i want to win a race by. set it at 6psi and if the other guy is catching me click it to 9psi, if he is still hanging then click it to 12psi, still there? hit the 100shot
but yeah it would work great for traction limited set ups, it would just ramp it up with the mph.
What?! The first step to recovery is admitting you have a problem.
Parish, I want more info on how this thing works. Do you run a boost line to it? Does it have a remote restrictor that you cut into the wastegate boost reference?
Parish, you might want to wire a button closer to your steering wheel, cause trying to mash that button while you're pulling hard G's and trying to keep it straight could be tricky.
That's a pretty slick little setup there parish. When's the turbo kit coming?
this controler has WAY more features than i will ever consider using, i will probably just use the dial a boost feature but i asked a few people and this one was highly recomended.
with the programable chanels it wont push the boost any higher than i have it programed for. the know also has a nice click when you turn it so i think i can do it on the go but if it is a hastle i will just turn it to the limit of whatever fuel i have at the time and leave it there. then just worry about the nitrous button(tow haul ) when i need it.
Adkoonerstrator
I can't wait until your turbo kit arrives.
Maybe a line lock button or something.
i am not completely sure how it works but it doesn intercept the line to the wastegate, there are 3 parts, the dash remote, an under dash controler and an under hood "duel soloniod" thing. one of the main features of a boost controler like this is it can get the max boost faster, supose to be alot faster.
I know its a momentary contact button, so how do you get it to activate without holding it down? I know the tow/haul light stays on when you push it once, so what wires do you intercept?
More info please! This is what I want to do when I get my wet kit.
Adkoonerstrator
That tow/haul button thing would be sweet!
