I blew it...
#41
My injectors have been maxed for a long time, but I'm not seeing any lean spots from them. I think they max out about the same time the MAF maxes out. I'm thinking the maxed MAF might have something to do with the injectors maxing, but I dunno about that.
#42
single digit dreamer
hmm, richard.. better be carefull with that thing, adding fuel with PE may have no effect
#47
Originally Posted by BigTex
That must be 10 hp at the flywheel, correct?
So ... that would be 600 - 60 for the blower, which would come out to 540, minus ~20%. Ending up at about 430.
#48
yep, yep, and yep.
for me 60lb's is a little under 500rwhp, that works out to about 20% driveline loss. with my converter locked that is probably a decent guess.
dont really know how to extend the maf freq into lb's, have you seen the maf chart from edit? it is going up prety fast at that point. looking at the chart i see 45lb's at 11hz and 60lb's at 12hz so if you continue a little acceleration on that ramp i would guess if you hit 13hz you might be between 75 and 80lb's
what all do you have done to that motor richard? you must have a nice cam and some decent heads on there? along with some good exhaust? at 8psi in the cold with an intercooler i am just bumping the maf limit. stock heads could be hurting me quite a bit i suppose.
#49
Minus blower drag too I think.
Where does 430rwhp cross on this radix dyno?
https://ls1tech.com/forums/showthread.php?t=250912
#50
I didn't see 13K Hz, but it did get to 12,700 near 6400 rpms.
I haven't installed my heads yet. Just comp 218 XE high lift cam, ASM headers with 3" collectors, dual 3" echaust w/o cats, and most other bolt-ons. I'm currently running a single 3" out muffler though. In the last two days, its developed a nasty exhaust leak at the 3 bolt collectors. I think the backpressure blew out the paper gaskets.
