i got my pacesetters long tubes installed
Not trying to hijack, but xdanny510x how are you running the long tube pacesetters here in CA? I want to go with similar ones, but smog issues are stopping me. Any long tube headers for that matter.
PM me with info. if you don't want it on this thread. Thanks.
Originally Posted by DozerDan
I have a rattle on my pipes coming from a heatshield and from the pipe hitting the crossmember...didn't happen til the true duals
oh im just gonna run the long tubes without the cats for a couple months until i get enough money for the turbo then im gonna switch back to shorties with a magnaflow hi flow cats
I had the same problem and I just cut my shield back a little bit on the motor mount mine hit the worst on the drivers side but I just cut them both.My pipe is also very close to cross member abought a 1/4 in or so have not drove truck yet thought winters here you know I will find out in the spring (lol) Just buy a bigger cam so you wont here it
After I put on Dual Exhaust, everytime i hit a good bump (every five feet in saskatchewan), i would get a knock sound. Went under the truck and it was a bolt from one of the cab-mounts, so i trimmed it to the nut with a dremel.
I could tell it was the one because where it would hit the piped it would leave a mark!
Does a guy really need that heat shield? I was looking under there one day, and I wanted to cut it in half, unbolt it, and rip the POS out of there.
The reason I don't think I need it is because my stock muffler is gone and there is only two little bottles there now!
Offroadunleashed
07-20-2015 02:25 PM
Suburban2500
07-13-2015 09:57 AM
