I have 3 cam choices. help me decided
These are the choices I've come up with.
214/218 .600/.598 115 lsa on 110 icl
216/220 .600/.598 115 lsa on 110 icl
220/224 .600/.598 114 lsa on 110 icl
Goal: To get the fastest 1/4 mile time i can out of this stock 5.3 with my mods and still have a daily driver. i'll be happy with 11.99 - 11.5.
My mod are:
complete true dual exhaust no cats.
Edlebrocks lingenfelter 61969 heads(on the way)
ps1 procharger 8-10 psi now.
Flt l5 4l65E
meth kit
2600 pi stall will only break stall to 2500 now
3.90 truetrac rear.
+ whats in sig.
everthing else is stock.
My mod are:
Flt l5 4l65E
meth kit
3.90 truetrac rear.
+ whats in sig.
The procharger will make more difference than any of the cams will. Since you have the procharger coming for real power, I'd go very conservative on the cam choice to keep your daily driver torque where you want it. I'd run with the 214/218.
To be honest, the 214 cam is already big for the 5.3L compared to my standards, but I've gotten into many debates about my cam selection. I go after low end torque that pulls all the way usually past red line that can be used with the stock torque converter or something that stalls just a little higher...like your 2600. I don't like big cams that don't make power until 3000+ and redline at 8000+. The 214/218 will be a torquey cam down low and you'll have the procharger to do the rest. It's roughly a 1300-6500 rpm cam in a 5.3L and you have the supporting head modifications to take it all the way up there, so if I were driving your truck I'd opt for that cam for hard launches and daily driver manners. Let the forced induction take care of the high winding "play time".
