I have oil in my intake runners please help!
Old 07-19-2006, 11:14 PM
Dark Halo's Avatar
well I do no not have the right fitting need to use the manual gauge up top so I am replacing the sending unit one more time and if the lower pressure is still there I may try and find someone with the filter mounted gauge.
Old 07-20-2006, 02:12 AM
jblack6527's Avatar
Originally Posted by Dark Halo
My father and I built the motor. We had a local machine shop put in the cam bearings, and we did everything else. The pressure seemed good until the sending unit went out and now it is low with a new sending unit. I do have a manual guage but it goes in place of the dending unit, I will be testing it today.
Maybe the sending unit is bad? If it was fine before, i would look there first..
Old 07-21-2006, 10:53 AM
Dark Halo's Avatar
yea I replaced it again, I think it is the orileys units.
Old 07-21-2006, 03:45 PM
Pressure good now?
Old 07-22-2006, 12:54 AM
Dark Halo's Avatar
it's better through the rmps but still the same at idle, maybe the machine shop screwed me on the cam bearings. Luck has not been on my side in 3 years now so who knows.
Old 07-22-2006, 09:44 AM
PT's Slowest Truck
budhayes3's Avatar
How about the oil pump pickup tube o-ring? I know alot of guys have had issues with different size/style o-rings not fitting properly. I'd also check and make sure it's in straight and not kinked.
BTW, I did more research on those intake rocker bolt holes, and it's common and normal for ported heads. Some liquid teflon or other sort of sealer should fix you up.
Old 07-22-2006, 09:57 AM
Zick's Avatar
Hey Dark, did you get my return pm? How do you have your PCV system setup? I know after getting rid of my pcv completly I have 99% less oil burning issues.
Old 07-22-2006, 02:52 PM
Grumpy5.3's Avatar
you may also have a oil pump itself going out.... I have replaced many of them at work for low oil pressure.... I have also replaced a few clusters b/c of this also. I would get an adapter to replaced the oil filter, put a manual guage on it, get some kind of scan tool that will allow you to see data, and compare all 3 of them at once. If the manual guage and scan tool are reading ok then you need a cluster... hope this helps
Old 07-23-2006, 12:30 AM
hog
hog's Avatar
Maybe you dont hav ethe proper main bearing clearances, they are smaller on the GEN 3 engines than the GEN 1, Gen 1E or GEN 2 engines.
peace
Hog
Old 07-23-2006, 01:22 PM
MorepowerTY's Avatar
Do you have a cold air intake system? If you do, it could be from over oiling the filter. That's what I did to mine. Just a thought.
Quick Reply: I have oil in my intake runners please help!
